Tunisia
aldarisk
Can’t make any calls not even to customer support can anyone help? I’m in Tunisia sand can’t seem to find an online chat with customer support?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
Does your phone show a connection to any local networks? In other words, is this an issue of no coverage abroad?
Or does your phone have a local network connection, and this is purely an issue with outgoing calls? Did you receive the welcome text message on arrival abroad?
