10-09-2024 11:54 AM
Hello,
currently in Tunisia and haven’t had signal for the past 3 days I’ve tried everything, changing signal to 4g, automatically changing providers out of the three I can choose one sometime picks up but with no bars, my partner has full signal, I’ve turned the phone on and off, turned roaming on and off, turned flight mode on and off!
please help thanks
Aaron
10-09-2024 11:57 AM
Hello @AaronH94 ,
Welcome to the community,
Are you on pay as you go or monthly contract?
Did you first use your SIM card in the UK ?
If on monthly contract, did you activate roaming on your account and did you receive the welcome message?
On pay as you go, roaming is automatically enabled.
10-09-2024 12:03 PM
I am monthly contract, I activated roaming abroad on the app before coming yes, I have had signal previously abroad back in may in turkey, I also used the SIM card in uk first yes
10-09-2024 12:05 PM - edited 10-09-2024 12:06 PM
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
10-09-2024 12:06 PM
Thank you @AaronH94 , you may have to ring customer service, as it seems you have tried everything, and as I am a customer like you, I have no idea otherwise..
10-09-2024 12:10 PM
You can't activate roaming using the app; only be text or calling CS. You just bought a roaming billing add-on with the app but that doesn't of itself activate roaming on your a/c.
10-09-2024 12:41 PM
Just to clarify, is that 3 days the duration of the time you've been in Tunisia? Or have you been there longer but only had coverage initially before subsequently having problems?
