I’m in Tunisia & have no service only WiFi in hotel 🤦‍♀️
Nev6459
@Nev6459  are you on contract or pay? Go? Have you tried restarting your device? If on contract did you text ROAMING to 150 to enable roaming on your account before you left the UK ?
Schockwave
Hello @Nev6459 ,
Welcome to the community,
Are you on pay as you go or monthly contract?
If on monthly contract did you activate roaming on your account before going abroad?
Not necessary if on pay as you go, as it is already automatically activated.
Have you tried doing a manual search for a network rather than automatic?
If you are on a monthly contract you can ring customer service to get roaming activated by calling them on Skype for free, see my signature.
@Nev6459 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
