Roaming not working in France
Ismail2013
Hi:  I’ve got roaming as a free add on with my contract but it’s not working in France. My spend limit cap is set at £10. Can you assist?
@Ismail2013  What billing add ons you got doesn’t enable roaming  that only keeps costs down. To enable roaming you text ROAMING to 150 before you leave the UK.   You will need to contact EE customer support tomorrow now to have roaming enabled on your account.   You can use live chat via the  EE app under help.   But it’s probably going to be quicker if you can call them from a different phone.
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
