Recent transfer to EE no incoming calls
DavidKidd
Recently transferred from another provider (ESIM) on 25/07/2026, I can see my number is on the system however I do not have any services yet, no incoming calls and no access to my data plan.
Any suggestions
Rgs
David
Alex_H
Hi @DavidKidd,
Welcome to the EE Community
Is it just a SIM only plan you have purchased from us, if so did you get your order confirmation email with the instructions for downloading your eSIM and were you able to download and install it ok?
When you say you can see the number in the system, what do you mean exactly? If you have installed your eSIM, have you restarted your phone since then?
Alex
