Re: My phone keeps cutting out when I’m on a call
Suerh45
Same with me.  It is so annoying!! Mine even cut out when ee customer service broadband were transferring me to mobile to complain about it.  I was listening to music and then bam, gone!!!
19 REPLIES 19
Suerh45
Katie don't know about you but when I tried to check the network coverage I couldn't find my Samsung A53 5G in the drop down so couldn't check it.
@Suerh45 : The A53 5G is there. Just scroll down the list or choose a similar model. It doesn't really matter. That drop down list is not v. smart.
Thank found it.
It says I have little or no signal indoors.  I think EE reckon I should stand outside in the rain to make a phone call!!
Christopher_G
Thanks @Suerh45
Do you have home broadband? WiFi calling may help you keep connected if you can't get signal at home.
Suerh45
I am Katie.  My phone cuts off during the call. Even VoLTE calls.
Hi Chris
Thank you.  My phone cuts out even on a VoLTE call.  It's really annoying.
Christopher_G
VoLTE is 4G calling, @Suerh45. Do you ever see VoWiFI, or WiFi Calling at the top of your screen?
 this is what is at the top of my screen Chris.
Christopher_G
What about when you're connected to your WiFi router, @Suerh45?
