EE numbers can't call/text me
gwahiir
Anyone have issues where EE numbers specifically can't call or text them?
So far I have come across two EE numbers that can't contact me. My number has been attached to different networks/sims/phones, so I don't think it is on my end.
9 REPLIES 9
Usually the opposite is the case, that if there's a problem with your routing data that "on-net" calls are OK but other networks may have issues.
Is this a recent problem?
Katie_J
Hello @gwahiir
Welcome to the community.
Are you using the EE Network?
Katie
Been nearly two years now I've known at least one number to not work. Just recently I came across another EE number that can't contact me. I can call them, but texts don't go through. They can't call or text me. Both people are on iPhones.
I'm not. I'm on Three. It's only been EE numbers that can't contact myself it seems. My number was previously on Lebara and it did the same thing, so I don't think it is with me.
Leanne_T
Hi @gwahiir
Do the EE numbers have your number saved as a contact in their phones?
If so, can they check the details of the contact and make sure the number for you is showing correct and not blocked in any way.
Leanne 🙂
They are stored and both correct/not blocked in any way.
Christopher_G
If they type your number manually into the keypad to call, does it go through, @gwahiir?
Got them to type it in manually and comes up as a message saying incorrect
number
Christopher_G
OK, thanks @gwahiir
I suggest speaking to our technical support team so they can look into this further for you.
Please keep us posted on what happens.
