Need roaming on my phone
JAB-1962
Hi could you please set my phone to roaming I’ve done everything on the app but still unable to make phone calls
16 REPLIES 16
Thank you
Sent from my iPhone
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything.
Thank you I will try all that now the phone is contracted and I didn’t do the roaming I didn’t realise I needed to I will try what you’ve just said to do thank you again
Julie burgoyne
Sent from my iPhone
JAB-1962
Hi
woukd just like to say thank you for all your help on trying to get my phone to work here in Spain it’s still not working so I use it when I’m back at the hotel using their wifithe community link is a fab idea and I’m sure I’ll need you again
xxxxx xxxxxxxx
[Mod edit: Please do not post personal information on the public board. Thanks!]
Christopher_G
You're welcome, @JAB-1962
Did you manage to speak to our Mobile Care team?
No I couldn’t get through to them
Sent from my iPhone
Leanne_T
Hi @JAB-1962
If you can try calling again when you get the chance the team will be able to help you get this looked into.
