09-11-2022 01:26 PM
Hi could you please set my phone to roaming I’ve done everything on the app but still unable to make phone calls
09-11-2022 01:32 PM
@JAB-1962 You f roaming is enabled on your account it can only sue upto 24 hours before it’ll start working. Have you tried restarting the device ?
09-11-2022 01:37 PM
Yes I’ve turned it off a couple of times I’ve done everything it said on the app it says to txt roaming to 150 but that wouldn’t work because I got no connection
09-11-2022 03:34 PM
09-11-2022 03:41 PM
09-11-2022 03:44 PM
Go into Settings > Mobile Data > Network Selection > Turn 'Automatic' OFF. This will search manually for available networks.
09-11-2022 04:05 PM
09-11-2022 04:17 PM
Hi @JAB-1962,
You'd need to try each network in turn to see if any connect.
If you have recently made changes to your roaming settings in My EE, it may take up to 24 hours for them to take effect.
09-11-2022 04:34 PM
09-11-2022 04:38 PM
If it's not stayed active on the app then it might have to be added by the Customer Service Team. You'll not be able to ring them if you don't have service but if you have wifi, turn on wifi calling and this might work. If not, maybe try the chat team, they might be able to do it for you.
