In USA. WiFi connection good, however nothing on moblle
Suemo27
EE is not linking to AT&T on my phone
therefore I cannot make calls or message. Went to Apple, after 1 1/2 hrs there’s nothing wrong with my phone. Help!
9 REPLIES 9
Schockwave
Hello @Suemo27 ,
Welcome to the community,
Have you tried a manual search if automatic search is not working?
There is more than one network there, I believe the other one is T-Mobile, try that, it should work, so long as you have made sure roaming is enabled, along with call abroad and premium calls.
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
Suemo27
Thanks, Tried all the networks just showing sos.
I pay monthly bought a USA add on before I came away
Have turned on off
Data roaming etc on.
Visited apple shop to get phone checked out, all ok. they just said it was
a connectivity problem from EE to the states.
No chat available at EE, cant call. So stuck
*Sue *
[mod edit: personal details removed from the forum]
Leanne_T
Hi @Suemo27
Thanks for coming here.
If you have a pay monthly account, could you check your roaming status by logging into your My EE account online go to Menu > Account Settings > Parental and Data Controls > Enable Roaming and also Call abroad, do they show as ticked?
Yes, all ok. I even purchased an add-on for USA before I left.
I've tried manually checking all networks, nothing comes up they just say
SOS
xxxxxxxxxxxxxx
[Mod edit: Please do not share personal details as your posts are visible to the public. Thanks!]
James_B
EE Community Manager
Hi @Suemo27,
Was roaming showing as ticked in My EE?
Which roaming add-on did you purchase?
Do you have a spend cap on your account?
@Suemo27  Have you restarted the device since you got there ?
I bought the one monthUSA etc roaming package.
My contract is monthly.
James_B
Hi @Suemo27,
Was it the Roam Abroad Pass you purchased?
