My calls
Pecata972
Sorry I am in Spain and I want to call number in uk but I can't help me please
@Pecata972  have you enabled roaming on your EE account if you are a contract customer?
Pecata972
I have data with my roaming but I can't call in uk I am in Spain help me please I try to do that from 2 hours
Christopher_G
Hi @Pecata972
Welcome to the community.
Is it a contract or pay as you go SIM card that you have? Have you tried manually searching for a different network?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
