I can't make call while I on roaming.
Thamor1
15 REPLIES 15
More questions than answers here...
Does your phone show mobile network coverage? Have you been able to make calls abroad from this phone previously? Can this phone send & receive texts? What happens when you try making a call?
"I can't make calls abroad" is an FAQ on this forum, and there's several pieces of standard advice may well apply. But some basic info is needed first, as per the above questions.
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
Yes.
1 'Yes'. many Qs!
@Thamor1 wrote:
Yes.
Yes to what? This is a classic case of "you can't provide too much info" but can easily provide too little. Which question are you answering yes to? And what about the other questions?
I still can't make a call  when I on roaming.
I am in Thailand. But  can't make a call when I used roaming.
@Thamor1 : You've already stated that in your OP but you've not answered 1 of @bristolian 's Qs. What's the point of repeating yourself? If you want help you need to help us help you.
Does your phone show mobile network coverage? Yes.
Have you been able to make calls abroad from this phone previously? Yes.
Can this phone send & receive texts? Only received.
