19-04-2025 11:41 PM
How do I call back to U.K. from USA? My phone may have a block on it but I can’t find out how to unblock
20-04-2025 01:59 PM
What makes you think your phone has a block on it? Does it show coverage of a local network?
20-04-2025 09:24 AM
Hi @BOB1015
You'll need to speak to EE CS and add roaming.
Download Skype and over wifi call EE with the number in my signature during UK office hours.
20-04-2025 01:59 PM
