Data Usage Alerts
sean3115
Can someone tell me how I change the data usage limit warning please?
@sean3115    Can you clarify if this is a built in device warning or a text message from EE.   If it’s the built in device warning then you’ll find the option to change this within the device settings.  As you don’t say what device is it it’s going to be hard to give you an exact answer.  It’s probably under data settings.
