America
Kyamre123
Iv purchased a plan for data in america
it connected one day but now not connecting
@Kyamre123 : Can you make calls & texts?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
Did you receive a welcome text message on first arrival in the US? If you were able to connect once and have had problems since, that suggests your roaming was working and is thus setup.
Try connecting to an alternative local network.
