on 21-06-2024 12:47 AM
Hi
im in france. But unable to use my data. I can’t seem to add roaming.
Any advice greatly appreciated
on 21-06-2024 02:57 AM
@Hevdg7 : Can you make calls & texts?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
