26-09-2026 12:19 PM
My phone setting says SET UP for Roaming yet EE says I asm not! I am a Business Customer and have been HANGING ON TGHE PHONE for 27 minutes now. Obviously MAJOR problems with customer first phylosophy since being contaminated with BT!!
26-09-2026 09:10 PM
26-09-2026 02:20 PM
Welcome to the community.
The business support team are the best people to speak to about this. They'll be able to make sure everything is set up from our side for you. Hopefully, you managed to get through shortly after posting.
Let us know how you're getting on please.
26-09-2026 03:40 PM
Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before leaving to go abroad?
If you are on contract, did you activate roaming on your EE a/c before leaving UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise if you are on contract you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. using a web-calling app over WiFi.
26-09-2026 05:03 PM
@basilhirniak wrote:My phone setting says SET UP for Roaming yet EE says I asm not!
How exactly does your phone says "SET UP" for roaming? And how exactly have EE say you are not?
Can you be specific on either point? Because you've not explained. You just seem to be here for a rant.
26-09-2026 09:10 PM
26-09-2026 09:30 PM
That's data roaming only not for roaming in general. It won't help you with calls & text.
Also that's for the device only not for roaming on EE.
27-09-2026 03:41 PM
@XRaySpeX wrote:That's data roaming only not for roaming in general. It won't help you with calls & text.
And to add, if roaming is not enabled on your SIM, then a phone setting for data roaming/voice roaming/text roaming (if the latter two existed) are an exercise in futility.
@basilhirniak You mention that this was "quite simple really" but didn't mention it in your first post. Users responding on here can only advise & comment based on what you post.
