they flat out denied there was any loss of service
Auricaargent
Same here and when I phoned EE about it they flat out denied there was any loss of service
[Mod edit: Please do not post personal information on the public board. Thanks!]
11 REPLIES 11
Auricaargent
You've hit on a key point about cellular technology: it's not a single, monolithic signal, but a complex system using multiple frequency bands. Here's a breakdown to help you understand:
1. Frequency Bands and Cellular Technology:
 * Frequency Bands:
   * Cellular networks (like 4G and 5G) operate on specific ranges of radio frequencies, called frequency bands.
   * These bands are like different "channels" for wireless communication.
   * Different bands have different characteristics:
     * Lower frequencies (e.g., 700 MHz) travel further and penetrate buildings better.
     * Higher frequencies (e.g., mmWave 5G) offer much faster speeds but have shorter ranges and are more easily blocked by obstacles.
 * Multiple Bands per "G":
   * Both 4G and 5G utilize multiple frequency bands.
   * A single 4G or 5G connection might actually be using several bands simultaneously (carrier aggregation) to boost speed and reliability.
   * Therefore, when someone says "4G" or "5G," they're referring to the technology standard, not a single, fixed frequency.
2. Network Configuration Changes:
 * Serving Site/Sector:
   * Cellular networks are made up of many cell towers (serving sites) that cover specific areas (sectors).
   * Each sector emits signals on various frequency bands.
 * Configuration Alterations:
   * Network operators constantly adjust the configuration of these cell towers to:
     * Improve coverage.
     * Increase capacity (handle more users).
     * Optimize performance.
     * Repair or replace equipment.
   * These adjustments can involve:
     * Changing the power levels of different frequency bands.
     * Adding or removing frequency bands.
     * Adjusting the direction of antennas.
     * Software updates to the cell tower equipment.
 * Impact on Coverage/Performance:
   * As a result of these changes, the coverage footprint and performance of 4G and 5G in a specific area can change.
   * For example, if a network operator reduces the power of a specific 4G band, users in that area might experience weaker 4G signals.
   * This is why someone may experience a change in service, even if the general 4g or 5g service has not been removed.
3. Why Operators Don't Arbitrarily Disable Coverage:
 * Network Optimization:
   * Network operators invest heavily in their infrastructure and strive to provide the best possible service.
   * They don't intentionally disable working coverage unless there's a strong technical or economic reason.
 * Customer Satisfaction:
   * Disabling coverage would lead to customer complaints and churn (customers switching to other providers).
 * Technical Reasons for Changes:
   * Changes are more likely due to things like:
     * Upgrading equipment.
     * Re-allocating frequency bands.
     * Addressing interference issues.
     * Optimizing the network for better overall performance.
In Summary:
The key takeaway is that cellular networks are dynamic and complex. Changes in coverage and performance are often the result of ongoing network optimization,
not the arbitrary removal of a "G" service.
rhysster974
@Auricaargent any updates on your signal? Have you got 5G back yet? No movement here over 6 weeks in. Starting to think they’ve changed the mast alignment. Really need EE to update the local mast (not even 100m away) into a 5G mast.
