Network problems in Pinner, Harrow (NW London)
Jakob_141
We have experienced network issues in Pinner, Harrow (postcode HA5 3**) for nearly a week. This is causing issues as we rely on this network as our main source for internet connectivity. Usually similar issues have been resolved within a day or two at most - is there an estimate of when the ongoing issue may be resolved?
Under the "find out more" link, there should be an option to "keep me updated" by either text or email.
From looking at the status myself, it refers to an upgrade. My suspicion is that this means additional technologies and/or frequency bands being added (basically, extra radio spectrum).
If this needs a physical reconfig of the site, antennas or radio kit, it can often take a few days to complete. There are numerous permutations depending on the individual pre & post-config.
Schockwave
Hello @Jakob_141
Welcome to the community,
That would depend on the problem, as to how long it can take, we have no idea in the community, this is a public forum with no access to areas.
If you have reported it, registered, then you will get updates.
Northerner
Hi @Jakob_141
Have you checked the status checker for issues as the above image is the network coverage check.
I get the Met past pinner and I'll check tomorrow morning 😉.
Jakob_141
Thank you, while I use an EE SIM card for the router, the contract is with National Broadband so I am not able to get more information than the "problem in your area" notice on the EE website. If it is a network upgrade I am hopeful it will be resolved soon.
Leanne_T
Hi there @Jakob_141
If you register for updates as @bristolian has mentioned, you will be kept up to date by email or text when we have more information and any work needed has been completed in the area.
Hope this is all sorted soon 🙂
