Bit of a contact loop
Sustech
Went to Japan earlier this month. Purchased a World Passport (unlimited calls and texts, 1Gb data per day) add on so I can use my phone over there. Landed, turned phone on,  data service only and no calls or texts.
This is where I found the infinite contact loop. Tried to log onto EE to find out what to do. "we are sending you a text code".  This is obviously not going to get to me. Couldn't find any other way of contacting EE. No phone, no text. Luckily I could connect to WiFi most of the time and the data service did work. My wife tried to talk to EE in the UK but was rejected a number of times. Just got the bill, have I got rights to go back to EE and ask for a reduction in the roaming charge seeing that I didn't get the whole service?
Debbie_G
I'm sorry to hear about the issues you had while in Japan, @Sustech
I’d recommend contacting our team, they will be able to review the charges for your add-on and help further.
Debbie
11 REPLIES 11
Not obvious! Sometimes even when you can't send texts you are able to receive free texts.
As you are on contract, did you activate roaming on your EE a/c before leaving UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c.
No texts received. Looks like no network connection, even though I had data.
Yes, roaming was activated.
How & where? Do not confuse your roaming ability with your device settings for roaming.
In the UK, before leaving. Always make sure before leaving the country. Have been away a few times this year.
Anyhow, if I was getting the data service from this World Passport then the calls and texts should also have worked as on same plan. The bit I am getting at is the difficulty of contacting EE when you don't have the means to receive pass codes. No option to use WhatsApp or email.
@Sustech , have you done a manual search for a network?
Also did you receive the welcome message from EE?
The Japanese network appeared in the Network Operators section of the Mobile Networks in Connections, so was connected. As I mentioned, I had data but no calls or texts, so no welcome message from EE.
@Sustech , if you switch of automatic network and then try the different networks to see if you receive the welcome message and can make calls and receive text? You may have data showing, which shows you have roaming enabled, but we always advise customers to do a manual search for a network, in a case like this.
Duly noted for next time.
I'll probably get a local sim or Esim next time.
