data roaming services
Davidsea01
I have recently moved house
I currently have no data roaming servcies or wifi call
I visited my local store to update to a new sim card
My new home has no mobile coverage at all but I do have wifi
Are there settings I need to change?
Hoping for help
David
9 REPLIES 9
@Davidsea01 : Did you move house to another country? Roaming only takes place when you're abroad.
Hi
No - still in the UK
I have no mobile services on my phone ( browser/streaming/internet connection) unless I have wifi connection
I use this a lot for a GPS system app for my pets so it is vital
Any ideas?
@Davidsea01 : Have you Checked Status of the Network Status Checker there and reported your problem via that link?
Hi again
I have and the coverage checker says I have outdoor only coverage - true - ish
Even so - even WHEN connected to a mobile coverage - still no data received
Wondered if my plan was used up but this is fine
I never said to    I said to Check status .
Yes sorry I meant to say I've reported a network status problem
If any family or friends locally use EE, check whether they have similar issues - it may just be a pocket of poor indoor coverage.
If so, WiFi-calling is the ideal solution.
Hey Mark
I can’t even get wifi calling indoors right now
We have decent broadband speed
It must be a setting thing or my plan
I’ll keep trying
Thanks for the consideration
Cheers
D
Not sure who or what Mark is.
Do you have WiFi-calling enabled in your phone settings?
What happens when you try making a call? It maybe that mobile coverage is deemed sufficient for 4G-calling to work.
