Signal lost in suffolk
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
05-04-2023 08:13 AM
For three days I have had no signal where I go the coverage checker is saying I should have 3-4 bars but I have 1 bar everywhere I go.
how can I solve this issue ASAP!
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
05-04-2023 08:16 AM
Hi @Jessmillz
Welcome to the community.
Have you tried restarting your phone? Did you check the status on the coverage and network status checker? It will tell you if we're aware of any problems in your area, or let you report one.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
05-04-2023 08:21 AM
I’ve restarted the phone and my coverage checker says I should 3-4 bars but my phone has 1 bar
jess
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
05-04-2023 08:22 AM
Thanks, @Jessmillz
If you hit 'check status', instead of 'check coverage', It will tell you if we're aware of any problems in your area, or let you report one.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
05-04-2023 08:25 AM
No known problems. Just checked
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
05-04-2023 08:27 AM
If you report a problem on there, our network team will investigate whether there is a problem in the area, @Jessmillz.
Alternatively, if you contact our technical support team, they will be able to do the same and check to make sure everything is OK on your account.
