on 18-10-2022 07:18 PM
Hi EE world,
I have an odd issue where my phone only shows up to and including 2g. To be honest, it does show 3g very briefly, if you hold the phone up and wave it about, but then almost as quickly falls back to 2g. I've been using it for around 1.5 years, with no issues whatsoever.
I checked online for problems in my area, but nope. I check one of those sites where people report EE issues and there were a few hundred. So, on Sunday I contacted EE Network support and I told them I'd restarted, that I'd reset my APN, that nothing has changed on my phone, that I'd powered off completely, and back on again. Today, Tuesday, EE network support responded to tell me theres nothing wrong and that they suggest I restart my phone... Not helpful...
Anyway...
Other than resetting my phone back to factory, which may not resolve this, I am stuck between a rock and a hard place.
Any ideas? I have a Huawei P9 on Android 8.
Thank you EE world. :0)
Paul.
on 18-10-2022 07:35 PM
Perhaps it's best here to start from scratch. How long have you had this problem for? And does it happen in all locations or just specific ones?
Are you on pay-monthly or PAYG?
Do you know any friends or relatives who also use EE - do they have similiar issues in the same locations?
on 18-10-2022 08:32 PM
on 18-10-2022 10:10 PM
If you've only had this issue for a few days, I would recommend using the "check status" option on the EE coverage tool
This site has access to the EE faults database so is far more reliable for local issues than third party "is my service down" type sites, and also has an option for reporting suspected problems that aren't listed.
Any known issues have a facility to register for updates by text or email.
on 18-10-2022 11:27 PM
on 19-10-2022 02:11 AM
Hi all, how are you?
Well, would you believe it... A few moments ago I decided to go through my embedded mobile data settings, bearing in mind I haven't accessed them for many months, and I found a setting that screamed at me...!
I don't get it because I've not, and never have, changed this setting...!!!
Well, it appears to be fixed... I am seriously scratching my head right now...
Thanks everyone.
Paul.
on 19-10-2022 08:01 AM
Glad you got it sorted. Sometimes the simple things catch us out.
on 19-10-2022 11:32 AM
