Re: Call drop
LittleLath
I’ve been having the same today, it’s driving me mad
Can you explain the problems you're having with your EE network service?
Are you losing coverage completely, or are calls dropping with signal indicators present?
Is anything reported under "check status" on the coverage tool ?
Dropping whilst there is still signal
Please excuse the brevity and spelling of my message as it is sent whilst on the move.
xxxxxxxxxxxx
xxxxxxxxxxxx
[Mod edit: Please do not share personal details as your posts are visible to the public. Thanks!]
Does anything show under "Check status" on the coverage tool I posted previously?
If this has only been happening for one day there may be a local network issue - the tool allows you to "report a problem" if nothing is listed.
