20-03-2025 02:13 AM
Basically since 4g came to my area its been 4G+ but a few months ago, there was an issue in my area which took about a day to fix but since the fix im only getting 4G and not 4G+. I've noticed that the speeds have been lower too, the mast at my parents house has also stopped broadcasting it as well. They're EE 5G router used to display that it was connected to B3+B20 but now it only shows B3. Has anyone else had something similar happen? And is there a chance that reporting will actually get it sorted?
20-03-2025 07:36 AM
Check the EE status checker: https://ee.co.uk/help/service-status
There are various outside factors which impact signal strength, distance from mast etc..or even the tariff you have.
20-03-2025 07:59 AM
EE use "4G+" as an indicator for 4G-CA.
Do you still get B20 independently, when no B3 carrier is available?
