Network problems i live in Liverpool i cant make or receive calls so frustrating
Bagga72
I can't make or receive calls from my area i was with giffgaff only been with ee for a couple of months on a contract but I'm only getting bits of signal i want to end my contract because it's pointless having a phone that I can't use i need my phone for work any help would be appreciated
8 REPLIES 8
Katie_J
Hello @Bagga72.
Welcome to the EE Community.
Are you experiencing this in multiple areas of Liverpool or just the one?
Speak soon,
Katie
It's happening in different locations i need my phone for work if this doesn't get any better then il have to end my contract because it's pointless having a phone i can't use
Katie_J
Thanks for confirming this @Bagga72.
Have you been able to test your SIM in another phone?
What phone are you using at the moment?
Speak soon,
Katie
Are these in locations where good coverage is predicted on the website coverage map?
Do you know whether other EE users are having similar problems?
I' don't have another phone I'm using the one I got from yourselves it's a Samsung galaxy 6 flip phone if this issue isn't sorted soon I will end my contract with you
Michael_D
I understand you want to get it sorted @Bagga72, but we do need to establish if it is something with the phone or the network.
Have you checked the areas where you are having trouble on our network checker?
Michael
Bagga72
I'm gutted I switched from giffgaff to you absolutely useless having a brand new phone and a network that's useless because I can't make or receive calls I won't to no if I can get out of my contract
Christopher_G
Hi @Bagga72
Did you get a chance to take a look at the network status checker that @Michael_D posted above? It will let you know if we're aware of any problems in your area, and give you the opportunity to report one if we're not.
