Network and data problem
Julieta1
Hi i cant make call and movile data, i need help as urgent as posible! Thanks
15 REPLIES 15
Does your phone show signal indicators? If not, is anything reported on "check status" via https://coverage.ee.co.uk/coverage/ee ?
If you do have coverage, what happens when you try making a call? And what happens when you try using mobile data?
James_B
EE Community Manager
Hi @Julieta1,
Did the network status checker show any problems in your area?
Yes i checked and it was ok, i think is a problem with my data.
James_B
Hi @Julieta1,
Do you only have this problem in one location or everywhere?
I have this problem everywhere, it started yesterday evening .
James_B
Hi @Julieta1,
Are you using a pay as you go or pay monthly plan?
Im using a monthly plan
James_B
What happens when you try to make a call @Julieta1?
Can you receive calls?
