18-10-2026 02:15 PM
I had to relocate abroad (EU) and decided to change my number from monthly payments to PAYG. I made the change via Customer Service once I was already abroad.
However, since I relocated, I have not been able to make any calls, send text messages, or use my mobile data add-on using the EE SIM. Even trying to send a text message to 150 results in error.
After some searching, I have found out that because my SIM was changed from a contract to PAYG once I was already abroad, I have not connected to the UK network yet thus roaming is not enabled on my SIM.
Any solutions to this? I can only contact CS using a foreign number which is costly so I thought I'd ask here first!
(Roaming is enabled on my phone and I was able to use the SIM abroad previously when I had a contract, I also receive the "Welcome to" text messages from EE so I'm pretty sure that the issue is with changing the SIM once I was already out of the UK.)
18-10-2026 02:40 PM
Hi @Taknyosnero
As you have mentioned and as you have identified via searching there is no alternative way around this activation process which needs to be on the UK EE network for EE PAYG.
18-10-2026 02:40 PM
Hi @Taknyosnero
