I have problems with my phone network and the mast my phone rebooted twice
justinmarfell
I have problems with my phone network and the mast my phone rebooted twice and it  gooses to emergency calls,
please keep up dated
Problems with network radio sites don't cause phones to reboot.
If you perform a manual network search, does EE show as available?
i still having problems with it
@justinmarfell  Have you checked to see if there is a network issue in your area ?  You can do that via THIS and click the check service status tab.
Are you connected to WiFi at present? If you are you can use WiFi calling if you enable it on your device.
You set the device has rebooted twice was this you switching it off/on or has the device just restarted itself?
i am still having problems with my network and it is playing up really bad
Lesley_W
Hi @justinmarfell
This seems to have been going on for a while.
Have you spoken to our technical team about this yet?
Lesley
