WhatsApp stuck on connecting
Donna115
Hi
For the last 2 weeks my WhatsApp is stuck on connecting when using mobile data. It is fine on WiFi! I have the iPhone XR & my updates are upto date!I have done the following to try and fix it.
offloded and re installed the app
turned phone, mobile data, airplane mode on and off.
checked on general settings
Nothing has worked! However I may get a random message through from time to time which is odd!
Any help would be appreciated please
Thank you!
Northerner
Hi @Donna115
What are your content lock settings?
Try logging into your MyEE app then - Click on the person icon in corner - Settings and Permissions - Parental Controls.
Have you sufficient data?
Thanks,
13 REPLIES 13
Northerner
Hi @Donna115
Thanks,
OMG, you have fixed it!!! It was the permissions , they were set at kids under 13 for some reason.
Thank you so much 😊
Sent from my iPhone
Wow - I have had the same problem - this fixed it - thank you!!
Why does it default to Under 13???
Alex_M
Star Contributor
Star Contributor
It defaults to that so that children don't access age-restricted content.
Now you've changed it, you shouldn't need to touch it again.
Thanks,
Alex
 If I solved your issue, please click the solution button below!
 If you found my post useful, click the thumbs up button!
 To speak to EE, call 150 from your EE mobile or +44 800 079 8586 (freephone) or start a live chat.
Useful Links: My EE | Live Chat | Bills | Usage | Network Coverage Checker | Abroad | APN Settings | PM
Jw18973
Settings and permissions not working again when logged in the app
Leanne_T
Hi @Jw18973
Thanks for coming here.
Are you trying to access the settings in your My EE account or WhatsApp?
MSwan1962
I have the same problem. I have recently joined EE from Vodaphone and I cannot connect to Whatsapp.
Parental Controls are set to Adult.
Unable to connect...
Any advice?
Katie_B
Hello @MSwan1962
What happens when you open the WhatsApp app?
Are you connected to WiFi or using mobile data?
Katie
