20-01-2025 05:38 PM
Hey all, having a bit of difficulty and I guess the forums seem like the last place I can get in touch with someone without having access to regular cellular/phone functionality.
I'm overseas in Argentina, and here for a couple of months. Since landing on 11th Jan I haven't had any signal whatsoever on my EE SIM. I have an E sim which i use for overseas data so I haven't really minded much as I rarely use text messages or calls and have normal access to whatsapp/maps/browsing etc.
However I need to log in to a service which only lets me authenticate through SMS message so I decided to start looking into what I can do to restore my EE service to receive incoming texts, however the only options I have for contacting EE are using phone or SMS so stuck in a bit of a chicken/egg situation.
Is there some way to speak to customer service about getting my roaming activated to at least receive messages?
Ty in advance!
20-01-2025 05:44 PM
20-01-2025 06:33 PM
