Re: Why is my data being used so quickly?
AimeeR
I am exactly the same , nothing has changed on my phone . My home WiFi is very fast and I’ve ran out of data Pretty much and I’m 3 days in.
21 REPLIES 21
James_B
EE Community Manager
Hi @AimeeR,
Does your phone ever switch to mobile data when you are connected to WiFi at home?
mikeliuk
Hi @AimeeR ,
If you are rapidly running out of mobile data on an Android phone, I would highly recommend downloading the "Internet Speed Meter Lite" app which will give live details of data usage and will keep track of day-by-day data usage over cellular data and WiFi during the course of a month.
If instead, your mobile data provides your home WiFi, the best option is to monitor usage day-by-day using the EE app or website. By far the highest usage will be for things like 4K streaming. I currently use 6 GB to 8 GB per day and should hit between 200 GB to 300 GB per month.
iOS & Android smartphones have an in-built data counter which will itemise your data usage to individual apps, and provide this functionality. It should generally tally with EE's billing counters, although there are circumstances where small differences can be expected.
On Android at least, this inbuilt functionality will be within your phone's network connectivity settings, under "Data usage counter" or something similar.
NeilOliver
Same here, I’ve had BT mobile for years but was suggested I change to ee but whereas my BT data used to comfortably last me I’ve had to gift myself data from other family members & just received an 80% used again message, I’m doing nothing differently & my other family members have experienced similar. Why is ee data not lasting as long as my BT. Something is definitely amiss!?
Leanne_T
Hi @NeilOliver
Thanks for coming here.
Do you have a new device?
Have you downloaded any apps?
Thanks.
Hi Leanne, Nope, everything is as it was on BT but ee is eating the data. 🙁
Leanne_T
Hi @NeilOliver
Do you connect to WiFi at home?
What device are you using?
Hi Leanne, At the risk of repeating myself, we all have iPhones & all use is identical to how it was on BT & yes we all connect to our Home Wi-Fi at home. As you can see from other posts this isn’t an isolated case!? ee data seems to be used faster than your competitors? Hopefully this can be corrected!?
Regards, Neil.
Leanne_T
Hi @NeilOliver
If you give us a call on 150, the team will get this looked into further for you.
Leanne 🙂
