Personal Hotspot lets me play games but not connect to Xbox party chat?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
08-04-2021 11:10 PM
It let's me connect and play online but whenever I try and join a party or invite someone to a party it won't work at all? I seen there was some sort of fix for this
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
09-04-2021 09:09 AM
Hi @Treeny06
Thanks for posting about this.
I hope you're well and having a nice day, are you up to much?
I'm a gamer myself so totally get why you'll want this fixing as fast as possible.
When you try to connect to a party, do you get any error codes when it fails?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
09-04-2021 09:19 AM
open or moderate I'm just hoping this can be sorted out
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
09-04-2021 10:01 AM
NAT codes can sometimes cause these issues so you may be right.
Have you looked over the Troubleshoot NAT XBOX support page at all? It's full of great information and steps to try when facing these kinds of issues.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
09-04-2021 10:16 AM
my phone to hotspot the xbox
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
09-04-2021 10:36 AM
I see, sorry I didn't realise you're using your phone.to connect.
When you tether via any mobile device, most gaming consoles will automatically change your NAT to NAT Type 3, which means that access is restricted.
Can you double check your XBox's current NAT type by following the below for me?
- Press the Xbox button on the controller.
- Go to the System tab.
- Then go to Settings.
- Then go to Network.
- Then go to Network Settings.
- Check what it says next to NAT Type.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
09-04-2021 11:24 AM
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
09-04-2021 11:30 AM
You sure it not xbox as I had the same issue couple days ago. I haven't tried since though.
If your NAT is set to strict then this could also be the issue. It needs to be set to open.
BrendonH (Android Expert) Google Pixel 8 Pro Obsidian Black (Android 15)
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
09-04-2021 11:35 AM
Vodafone skincare everything works, when I use my own on ee everything
works but the party chat. It's a fault with EE
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
09-04-2021 11:46 AM
You can't determine it's a fault with EE just by that.
Have you googled it?
Try this.
https://www.windowscentral.com/how-get-open-nat-xbox-one-enabling-upnp
