18-07-2021 01:58 PM
Hi folks my first time in the community. Had issues with my old Nokia 1520 (screen issues) Bought a used 1520 locked to EE from ebay. Though it would be straight forward transferring my PAYG sim which i currently use (EE) At my wits end - cannot log into microsoft account, store, emails ect keeps coming up with data issues. Can brows through wifi thats about it. Looking at solution after solution without success changing APN etc ANY ONE help please Missing My Phone access 3rd time full reset without success![wp_ss_20210718_0001[1].png](/skins/images/1DA91AA7239B310E5E4C13A00EBB8774/responsive_peak/images/image_rejected.gif)
18-07-2021 03:57 PM
Hi @SSmith60,
Are you unable to log into your Microsoft account during the initial setup of your phone? If not, which error message do you see?
19-07-2021 02:53 PM
Hi James - get onto wifi ok every other action Microsoft, store, email comes up unable to connect
19-07-2021 03:44 PM - edited 19-07-2021 03:45 PM
Hi @SSmith69
Are you able to make phone calls and send text messages OK? Does your phone show a good EE signal when WiFi is switched off?
19-07-2021 04:28 PM
Yes good signal everything fine, calls, texts and can browse internet thro wifi. Everything else, microsoft account, email add account and store cannot connect
19-07-2021 04:37 PM - edited 19-07-2021 04:39 PM
Try changing the last field in the APN Settings from IPV4/6 to IPV4 Only
Note- you may have to set up another Profile and copy across all the Fields to the new Profile the set and save that as your default APN, call the New Profile Name EEipv4only or something like that.
Save and restart phone, check its stil set to the new profile after restart
19-07-2021 05:06 PM
Thankss but Did not work - loosing faith now
19-07-2021 05:46 PM
Switch the Phones Data to 3g Only or below and test again
