08-09-2023 05:21 PM
I connected the 4Gee mini wifi to my laptop for work and it says connected secured but when I try to log into the laptop for work, it says that it’s not able to connect because the 4Gee wifi does not have a domain?
08-09-2023 09:11 PM
Issue the command ipconfig /all on the PC.
08-09-2023 09:32 PM
08-09-2023 10:05 PM
Sorry, can't help you then on such a restricted PC.
Sound's like it's your works' doing by placing restrictions on it & the answer must lie with them. Talk to your IT peeps.
