10-09-2023 02:25 AM
I’ve recently moved to a rural location and signed up for a 4G router. I’m getting download speeds of around 30mbs which is tolerable but upload speeds of 3 to 4 mbs which is dismal.
Is this a reception issue or just a limitation of the system?
If it’s reception would speeds be improved by an roof mounted external antenna? What type are most effective? Omni or directional? Does signal boosting make a difference? Is mimo important? The router has two antenna connections, are there versions with 4 and would that help? What brands are recommended? Is the EE antenna any good?
I’m new to all this and any advice would be a great help. Many thanks.
10-09-2023 11:47 AM
10-09-2023 11:50 AM
Hi @Tony219
I see, thank you.
You can use the message us option on the get in touch page here - Contact us about your mobile broadband (ee.co.uk).
10-09-2023 11:57 AM
No that doesn't go anywhere either.
10-09-2023 12:11 PM
It makes no difference with my external Ariel. Speed is rubbish full stop.
10-09-2023 12:18 PM
that's disappointing. what aerial are you using?
10-09-2023 12:25 PM
It says fullband on it and a tp-link router. Think mine is just down to the fact that signal is bad here anyhow.
10-09-2023 12:30 PM
is it on the roof of the house or indoors?
10-09-2023 12:48 PM
10-09-2023 12:52 PM
You seem to ended up with Home Broadband help line. Try calling CS on the Freephone no. (Opt 2) in my sig.
10-09-2023 01:01 PM
Thanks but I'm getting a 20 min wait time, so I'm giving up for now.
