5gee router (nr5103) not switching to external antenna
Harper86
I have connected up a 4x4mimo external antenna to my 5gee Nr5103 router. It is not switching to the external antenna even though i have put the switch on the back to EXT. I cannot find any find any settings to change, has this external antenna been locked off by EE?
I know the external antenna isn't working as the router is now hidden behind my tv where it gets a poor signal using the internal antenna, it is currently connected to the external antenna but speeds haven't improved. When i move it out to the window sill but leave the external antenna connected, speeds improve greatly.
Michael_D
Hi @Harper86
There may be some help if you have a search on previous posts on the community.
If you can't find specifically the help you need, it may be worth giving our tech guides a call so they can see if there is anything else to try.
Michael
Michael_D
Hi @Harper86
Michael
