on 24-08-2024 07:03 PM
Hi
I’m hooking up a you view box to my mobile 5g router.
I am getting a strong 5g signal.
my youview apps are all up to date and the youview box does connect successfully to the router
what I can’t run though is some tv streaming services like itvx
with ITVX I can select the programme to watch but just before it plays it drops out. I think the app crashes
has anyone seen this before and have any ideas how I can fix?
thanks in advance
chris
on 24-08-2024 09:26 PM
@copey5446 Just to check is this an EE you view box ? If it is it will not work as you need the EE smart hub plus router and you get that with having New EE broadband and having a EE TV subscription.
