Netflix on 4G EE router
AB20001
Just connected my 4G router. Currently regretting the move to EE. Can't load Netflix on my Sony Bravia. Can connect to Netflix on my other devices but not the TV. I still have the Gigaclear connection which I have tried and it all works fine . Go back to EE router and I get a can't connect code. I have done the on and off thing many times.Can anyone help before I pack it all up and send it back. Thank you
12 REPLIES 12
Yes I see them now thanks
I have now accessed.the router. Easier than I thought. I cannot find a page  for profile management or any of the settings in your picture. Is this because I am looking on a phone not a laptop.
Matt_124
If you look through the various tabs, it may be under something to do with data connection or advanced settings, I can't remember and can't access one currently as I am away.
It should then appear in the menu in the top left when you get into the appropriate section.
