on 08-08-2024 12:10 PM
On the EE website you need the mobile phone number to link a new device to the account.
But on the router you don't know the mobile number.
I've got the KEEP ME CARD but it only gives you the network number and key.
There is no phone number on the SIM card either.
How are you meant to add the device to the account? Is it possible to link a PAYG device to your home account?
I don't know how to check how much data.
How do you check what's left? Is there some phone number to call?
I've spoken to your team in Plymouth but they don't know either!
Solved! Go to Solution.
on 03-09-2024 11:20 PM
@AndyFoz1 : Then my link can't possibly work for you as you need to be on a locally connected device.
on 18-10-2024 02:50 AM
I read what you wrote but they ask for the number before sending a text message but i cant access the message as the sim is in the EE 4G WIFI gadget, i may have misunderstood but if i dont confirm the number they send i cannot go further, please can you let me know what i am doing wrong? Thank uiu
on 18-10-2024 07:36 AM
@Sha117 : Most mobile routers can receive texts. Login to it & look for the SMS Section/Inbox.
