on 08-08-2024 12:10 PM
On the EE website you need the mobile phone number to link a new device to the account.
But on the router you don't know the mobile number.
I've got the KEEP ME CARD but it only gives you the network number and key.
There is no phone number on the SIM card either.
How are you meant to add the device to the account? Is it possible to link a PAYG device to your home account?
I don't know how to check how much data.
How do you check what's left? Is there some phone number to call?
I've spoken to your team in Plymouth but they don't know either!
Solved! Go to Solution.
on 08-08-2024 02:12 PM
Mobile routers contain a SIM. All SIMs have a mobile no. Visit http://add-on.ee.co.uk/status from a device connected to your mobile router by WiFi to see your data & credit status as well as its mobile no. at the top.
on 08-08-2024 02:30 PM
Thank you! That works! I can now see how much data I have! According to EE it's not possible to link your home broadband account with a PAYG account using the SAME e-mail address. You have to use a different email address and create another account just for your PAYG account. Crazy.
on 08-08-2024 02:34 PM
on 20-08-2024 03:38 PM
Hi
That link doesn't seem to work for me, is there another way please or a different link?
Thank you
Andy
on 20-08-2024 03:44 PM
@andyfoz111 : Use another browser, not Edge or any browser that turns HTTP: into HTTPS: . Chrome works on it.
on 20-08-2024 03:53 PM
Superstar, thank you!🙏🏽
on 03-09-2024 09:26 PM
This link is not working for me, from Chrome - is there something else I can try to get the phone number of my router sim please?
on 03-09-2024 10:13 PM
@bmcc1982 : Put it in a phone.
on 03-09-2024 11:02 PM
I would but it is 250 miles away in a router
