04-09-2024 05:33 AM
Hi all,
I've recently started having random connectivity issues with my Sierra Wireless 4G router, and would appreciate some help with how to configure it to reliably connect to EE's 4G service. The interface provides the following options:
04-09-2024 05:45 AM
@EError : You could try:
Network Authentication Mode: PAP
Network Username: eesecure
Network Password: secure
04-09-2024 05:50 AM - edited 04-09-2024 05:57 AM
Thanks. That's weird because I've been using this for years without setting an APN or user credentials; when the router connects (which it did just now, without me having changed anything) its says "APN in use: general.t-mobile.uk" 😕 I'll try setting the user credentials and see if that improves things.
Edit: What about all the other settings, do I just leave them as is, or can I improve things by changing them?
04-09-2024 06:01 AM
I set "APN override" to "everywhere" and added the PAP user credentials; after rebooting the router now says "APN in use: everywhere".
04-09-2024 06:04 AM
But does it work?
04-09-2024 06:09 AM
It works, but as I said the router reconnected by itself just as I was posting, and before I had changed the APN & credentials (showing "APN in use: general.t-mobile.uk"). So I can't tell if these settings made any difference!
04-09-2024 06:18 AM
Here's what the connection looks like now; not great, but not terrible either:
05-09-2024 07:42 PM - edited 05-09-2024 07:56 PM
And yet again I now have "No Service", despite reasonable signal:
06-09-2024 07:46 AM
Still "no service" 24 hours later.
06-09-2024 01:37 PM
I'm sorry to hear that you're still getting no service after 24 hours @EError
I'd recommend giving us a call on 150 from an EE phone or 03301 231 105 from any other phone, then our technical support team can get this looked into a bit closer for you.
Chris S
