EE Data Unlimited - D-Link G416/B Mesh Router - Frequent Disconnections
OB1e
Valued Contributor
Valued Contributor
This is getting worse. When this indoor router was first installed I was getting up to 100mbps now its reliably 20mbps.
Heres what I know: the operator is 23430 LTE+ Band B20+B3 it started off as B3+B3. Signal is -51,0dBm.
On one occasion the network disconnected and I was able to login to snapshot the home page.
It showed that the connection type was now LTE, Band B3, Signal -55dBm Cellular Connectivity said: Connected. Sim Card Status - Detected, Connection Type - Cellular, Network Status - Disconnected.
IPv4 Data: Not available.
Turning the router off and back on always cures the problem.
Anyone any idea why the cellular connection should apparently revert to LTE because this makes the router throw a wobbler or so it seems. Thx.
Jwbox911
Hi well only that my EE router is an askey hh20c, which cannot be configured beyond selecting 4 or 5g which seems odd, and it comes with no external ports or antenna etc etc , which seems odd as they never mentioned that 5g won't work in a old barn conversion with thick walls !!
my advice would be go elsewhere!
OB1e
Valued Contributor
Valued Contributor
Hi, if only, stuck with them until Dec 2025, £500 to buy myself out of contract.
