05-09-2023 04:32 PM - edited 05-09-2023 04:33 PM
Hi All
I have a 5G EE Wireless Router and now and again it keeps dropping internet between the router and devices, wired and wi-fi from PC, Phone, TV and Tablets. Sometimes it can come straight back on, but most times I have to keep logging in to restart the device, or turning the power button off and back on.
I want to try and forced Firmware update, just incase this is the issue, but cant see where I can do this. Does anyone have any ideas?
Thanks all.
on 05-09-2023 04:53 PM
@BigBroGamer : I doubt the router has any firmware update facility, esp. if you can't see it anywhere in its management console. Firmware updates will be auto d/loaded as & when EE decide.
on 05-09-2023 05:49 PM
I keep checking for a Firmware update on the console, and it keeps saying I have the up to date version. I just wasn't sure if there was a way to force an update through, in deleting the firmware I have on mine, and replacing with the update button, just incase mine has a bug or something and is the reason it keep disconnecting now and again.
on 06-06-2024 04:14 PM
I'm having same issue very annoying ! router disconnects and does not get back alone, i need to connect to it and reset or cut the power.
If you are able to get any solution please tell 😛
