No WPA2(AES) config in Main advncd settings now incompatible with Smart Plugs
JPH70
Just had a full reset performed remotely by EE agent to solve a digital voice issue.  Before the reset I had a perfect wifi setup  plus 3 EE extenders, with no issues.
Post update none of my extenders worked and none of my smartplugs worked.  I reset all my extenders - so now working but Smartplugs are still an issue.
My prior firmware did not force me to select a  dual mode - Main and Compatability Option.  I think everything was on a single page and I think I had high spec WPA2(AES) security set and this worked perfectly across all my devices.
Now I notice that Main is set to WPA3-Personal-Transition which I think is the problem now.
I don;t want too much EE I only want 1 Main service and I want the ability to have ALL my connections on WPA2(AES) etc with all the SAME SSID and Passwd.  Otherwise I need to resync all my WPA2 only compliant devices with another SSID.
I've tried WPA3-Personal-Transition in Main but this is incompatible with the Smart Plugs
I've turned off Main and tired just  Compatability on both frequecies and  using WPA-WPA2-Personal.  This brings in some SmartPlugs however this doesnt provide wifi  with Apple devices (such as Macs or Iphones) as the WPA security mode is too low it sees the SSID but will not connect.
Can someone help - can I get my old firmware version rolled back or has someone solved this another way or why can't under main I have the full suite of security version available including WPA2 (AES)  etc?
EE have you thought the functionality through here - I can't be the only one?
Screen shot is from EE help page
Hub: SH31B
Firmware : r2.68.18-R-1303195-PROD-83002
Maestro
Maestro
@JPH70 The new FW upgrade to the latest version does leave a lot to be desired, never mind that your equipment all began to mis function, i found the same after EE upgraded the latest FW and the network became highly unstable. The only thing i did not do was Factory reset the router. To start again you may wish to try this, reset the EE Router AND the smart wireless extenders with a factory reset to ALL. Then re-pair the extenders to the router. My other IOT worked ok on the Main wifi all though i had kept it on Performance mode and only set the WPA2 mode off operation, not an IOS user so had now real need to have the WPA3 mode of operation, which is now a must for wi-fi 7, and unfortunately the + is heading towards the Pro operation as a EE/BT Guide will have the common this is what it looks like, and stuff all others when it does not work as you are finding out NOW....
It got so bad that i have NOW left EE as a BB provider and this was the main reason, they completely messed up the Plus without thinking about others....
818ster
Im experiencing similar issues since the firmware update. Smart devices keep losing their network, and even my wife's and my daughters work laptops no longer connect. I phoned 150, and was told the issue was related to an openreach fault in my area. I questioned how a local wifi connectivity issue was related to openreach?! I was told categorically it was, and they sent out a mini hub in the interim, even though I already have hybrid connectivity.  I don't think the support agents have a clue if its not on their script!
@818ster : Connect your smart devices to the Compatible WiFi network.
Thanks for the reply. Reconfiguring 30-40+ smart devices is no small task, especially when some smart switches are behind cabinets etc. It's the fact that EE has made a major change to the hub firmware which has caused user connectivity issues without prior communication, is pretty poor. And then be told by "support" that it's a openreach issue is a joke.  As a person who's been working in IT for 30+ years, if I did that to my clients, I'd be marched out the door.
Moving  the smart devices to Compatible WiFi network maybe an answer, which I have already tried. But that shouldn't need to be done for laptops which are less than 2 years old. And yes, I've tried putting those the Compatible wifi too, and that worked briefly. Now having to use phones as hotpots because it's more reliable than the home wifi is a farce.
