EE Nano Sim compatibility with Netgear M6 or M6 Pro routers
sar_north
Hi - Does anyone know whether the EE Nano sim is compatible with the new Netgear M6 / M6 pro routers (unlocked and with sim card slot) and how best I can validate that before i spend a chunk on the router.
Alternatively, any suggestions for compatible routers?
Cheers
11 REPLIES 11
Hi there. I’m having exactly same
issue. Did you sort in the end?
Leanne_T
Hi @ldavisuk
Thanks for coming here.
Are you unable to connect any device to the router when using the EE SIM?
Does the SIM card connect to data in any other device?
