EE 5G Smart Router
PeterGr1
8 REPLIES 8
What about it?
PeterGr1
I have recently started using the Smart 5G router
even though the signal is excellent, I need to reset the unit at least 3 times per day, as nothing will connect to the internet via the router, until it has been reset.
has anyone any suggestions
cheers
Peter
Christopher_G
Hi @PeterGr1
Welcome to the community.
Could you pop your postcode into our coverage checker and hit 'check status' please? It'll let you know if we're aware of any problems in your area.
Hi Christopher
I’ve done a speed check from my phone, I’m getting between 50/75mbs, plus once I reboot the router everything works ok for a while, so I doubt there a signal issue
Christopher_G
OK, thanks @PeterGr1
I suggest having a chat with our technical support team so they can look into this further for you.
Keep us updated on what happens please.
Thanks Christopher
I’ll definitely give them a call, need to wait until I have an hour or two to spare, sometimes it take absolutely ages to get through to speak to someone
Florriejones
I’ve recently upgraded from the standard terrible eve Wi-Fi to the new 5G smart hub. It’s worked for max 2 days.. it’s now flashing blue and white, can’t connect to Xbox online, and can only use browser for searches the mbps at one point was at 12!! The service we’ve had from ee at full whack £ has been terrible.
Christopher_G
Hi @Florriejones
Have you tried restarting your router? Please also try popping your postcode into our coverage checker and hitting 'check status', it will let you know if we're aware of any problems in your area.
