EE 4GEE WiFi / MiFi Mini keeps crashing in Online Meetings
Matt12342
Hello, recently in the last few weeks my Wifi Mifi Dongle has been failing. I get so far into a call, screen goes blurry, people tell me I've gone off the screen, disconnects.
No problem with broadband generally keeping the signal, good usually, just suffers on online Zoom / Teams / Google Meet calls. Thankyou for your help.
Katie_J
Hello @Matt12342.
Welcome to the community.
Have you been able to check the area for any known problems?
You can do this using the Network Status Checker.
Katie
Hello, yes I've been using it across two counties due to work with the same issue
Christopher_G
OK thanks @Matt12342
I would suggest speaking to our Technical Support team so that they can run some diagnostic tests with you.
Thanks, turns out I need to upgrade to 4G Smart Hub.
