EE 4G WIFI mini 2 password lost
Skypower
Hello guys am writing from Cameroon my kids pulled off all the stickers containing all the password on my EE 4G wifi mini 2 and I don't know if anyone can help?
You can get me on WhatsApp XXXXXXXXXXXXXXXX
[Mod Edit: Removed mobile number]
Then you're stuffed! Tell the kids off.
CS might have some record of them, but I doubt it.
Christopher_G
Hi @Skypower
Welcome to the community.
I recommend speaking to our Mobile Care team to see if they can help you with this.
@Skypower : Which pwd have you lost? The WiFi pwd? Login to your MBB router at http://192.168.1.1 with the admin password found under the battery cover. Then, if the WiFi password is not also found under the battery cover, on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
The kids removed all the stickers with all the passwords so that's the
problem.
