on 09-06-2026 10:57 AM
on 09-06-2026 11:21 AM
@garyforteath Is there no label stuck on the EE Router somewhere if not you are going to need a replacement?
on 09-06-2026 01:14 PM
This is why you take a photo and back it up.
As @JimM11
on 04-07-2026 11:05 PM
Usually there is a sticker on the back of the router/hub, or in my case, on the back on the hub there is a section that slides up - the password will be on here. If still no luck, you'll have to manually factory reset the hub (pin hole on the back, depressed for 15-30 secs with a pin). If you do perform a factory reset, the hub will revert to the original password.
on 05-07-2026 10:42 AM
@Cr4zyHarpy : If there is no longer any label then factory resetting it won't make you any wiser .You'll still to call CS to see if they have a record of it or get a replacement router.
